ONTAP Hardware
FAS2520 with Onboard I/O:10G Base-T
ADDEDMARIORF3
Hello Guys,
I Have a FAS2520 with 4 ports Onboard I/O:10G Base-T (e0c, e0d, e0e e e0f ) -> (two for cluster 10G) and two are free, It is possible to use the ports e0c and e0d that are free in the HP Switch where the ports works in 1G ?
Thanks
-MRF
1 ACCEPTED SOLUTION
3 REPLIES 3
scottgelb
Yes.  Per the FAQ.  The FAS2520 support both 10GBASE-T and GbE..it will autorange.  You also have 2x 1Gb ports on e0a and e0b.
ADDEDMARIORF3
Hello Scotgelb
Thank you for yoiur response
What is the FAQ? You have the link for send me?
-MRF
