ONTAP Hardware
Can a FAS2050 be converted to a disk shelf?
JOEYNGUYENHP
want to know if the FAS2050 is like the FAS270 where it can be converted to a disk shelf and added to a 32xx series.
thanks
2 REPLIES 2
martin_fisher
Hi - Pretty sure you cant do this with a 2050, but honestly I havent tried either, would be very interested to know if anyone has done it as well.
radek_kubka
No, you can't - sadly there is no way to reuse internal 2050 (or 2020) drives behind a newer controller.
Regards,
Radek
