ONTAP Hardware
Can't boot a HA pair with my fas2750
unitech89e9
I set up a FAS2750 in my data center,
and shut it down,then move to my customer's data center!
When I cabling all the interconnect port and protocol port(CIFS,and NFS 10Gb port)  and boot the fas2750,
but without cabling the e0M,
I found it can't boot,
and I want ask that if it will not boot without cabling e0M port ?
If yes,why?
4 REPLIES 4
SpindleNinja
e0M shouldn't matter, might not be able to access the mgmt though.
What errors are you seeing on boot?
Double check that you connected e0a <-> e0a and e0b <-> e0b for the cluster network correctly.
unitech89e9
I cabling all the cluster interconnect to my switch,
So I think it will not any problem,
but the system console show the SP can't boot,
and the interconnect are not reachable
SpindleNinja
That doesn't sound right...  Is it just a 2 node cluster?    If so,  just connect e0a to e0a and e0b to e0b.   and make sure you are using the correct twinax cabling.
https://library.netapp.com/ecm/ecm_download_file/ECMLP2842666  page 3 opt A .
Also, you can loop the e0Ms together so they show link lights.
feel free to post photos or the output from the CLI.
paul_stejskal
Hooking to your own switch for cluster interconnects is not supported. I would grab a console cable, or see if the SP is up and ssh into that plugging it in as needed.
