ONTAP Hardware
Changing network in take over mode
sherifafifi
hi all ,
the current network configration for my FAS3240 in the rc file  is :
node 1 :
ifgrp create multi grp1 -b ip e4a e4b e0a e0b
ifgrp create multi grp2 -b ip e4c e4d
ifconfig grp1 `hostname`-grp1 mediatype auto netmask 255.0.0.0 partner grp1 mtusize 1500
ifconfig grp2  `hostname`-grp2 mediatype auto partner grp2 mtusize 1500
node 2:
i want to change it by doing the below steps :
1-take over node2 by node1
2-edit the rc file of node2 to be :
ifgrp create single grp1 -b ip e0a e0b
ifgrp create single grp2 -b ip e4c e4d
3-after doning changes in the rc file , will reboot node 2 by using "reboot" will not use the option -f
4-after node 2 startup ,i will start the give back from node1 to node 2 .
as shown below i will only change the mode from multi to single and instead of using 4 network ports will use two , the IP will be the same and the VIF name will be the same.
so when i give back from node1 to node2 the give back will work normally ? or that can not be done ( the point i donot want to have downtime )
and if the above cannot be done , is there a way to change the network configration with out having down time ?
your quick response is apprciated
1 ACCEPTED SOLUTION
thomas_glodde
source wont work as the Interfaces are already configured, you need to go for the reboot -f (which is disruptive, yes) or takeover/giveback
4 REPLIES 4
thomas_glodde
1) edit rc file on node2 (remove the -b ip as well, only needed for lacp/multi)
2) issue cf takeover on node1, new configuration will take effect immediately
3a) if all goood, issue cf giveback on node 1
3b) if all broken, edit rc file again and issue cf giveback afterwards
sherifafifi
ok i faced problem in the give back ,, any way every thing is normal now .
i need to change the network configration so i will do the following :
A- on node 1 :
1-vi rc file
2-change the the grp1 configration from  " ifgrp create multi -b ip e4a e4b e0a e0b" to "ifgrp create single e0a e0b"
3-save the file
4-source /etc/rc
B-on node 2 :
1-same steps done on node1 "point A1 & A2 & A3"
2-source /etc/rc
C-reboot each node , will start with node1 by typing "reboot -f " ( i know it will make it unavalible till it starts up"
D- after node 1 starts up , will start to reboot node 2 by typing "reboot -f" (i know it will make it unavalible till it starts up"
then check the CF after rrebooting and ifconfig and other normal checks.
is that ok ?
thomas_glodde
sherifafifi
ye i editthe rc file , then reboot -f each node it worked fine
