ONTAP Hardware
FAS2220 HA Version an 12 Disks. How Many Data Disks?
001115774
Hello,
we plan to buy a FAS2220 in HA Version, but we dont know how many Disk in the System are Data Disks.
We plan to buy the Bundle with 12 x 900 GB Disks an set it up as a Active/passive configuration. The Documentation sais: In this configuration, the passive node has only a root volume.
How many Disk does he need for "only a root volume".?
And how many Data Disk are then available for the active node?
Regards.
1 ACCEPTED SOLUTION
paul_wolf
We use this hardware for our remote offices and this is the configuration that we use to maximize space.
Node 1 - One aggregate of 9 disks (RAID-DP) with one spare.   This will give you approximately 5TB of usable space on the aggregate (7 data disks, 2 parity disks).  If space it really a concern you _could_ go RAID-4 here but I wouldn't recommend it for production data.
Node 2 - One aggregate of 2 disks (RAID-4) with no spares.  You will get alerts about there being no spares available but you can stop those by setting 'options raid.min.spare_count' to '0'
2 REPLIES 2
paul_wolf
001115774
Thank you.... That helps a lot!
