ONTAP Hardware
Cluster management Lif operational status: Down
Mocha_1982
Hi All
I am building a new cluster FAS8060 with OnTap 8.3.1 P1 and run into strange issue .....
When I failover from node 1 to 2, all works fine (data, cluster) except cluster-mgmet lif shows operational status: down ..
Also I also seeing a strange lif and not able to see/remove
cluster01::*> net int show -vserver cluster01 -lif
56181089-a41b-11e5-87e3-cda87b04185f_mgmt1  <============
cluster_mgmt
node01_mgmt1
node02_mgmt1
When I failover from node 1 to 2; I lost access to Cluster management IP (https/ssh), but ping still going through .... when both node are up firewall is seeing mac collision for the Cluster management IP address from both node ...
I am building another cluster at another datacenter with the same hardware, config and network setup; failover all works smoothly no issue at all.
Anyone one ran into similar issue before or suggestion where to look first ?
1 REPLY 1
Jeff_Yao
hi
try this kb to see if help
https://kb.netapp.com/support/index?page=content&id=1013870
if not, you might need to open a case for the dup mac address
