ONTAP Hardware
Config Advisor Output
CHRISMAKI
While I believe that this cluster *should* function fine this way, Config Advisor would lead me to believe that is not the case with its advisement that these cluster ports are wrong and are of "High Impact".
Any thoughts on why using e1b and e2b instead of their 'a' counterparts would have a high impact?
This is one of those config advisor outputs that has bothered me previously and just thought I'd throw it out there.
1 REPLY 1
aborzenkov
What is CA version?
