ONTAP Hardware
mixed and sas shelves
Amir
Hi,
I've got three shelves: 2 - mixed (DS2246: 4 ssd + 20 sas), 1 - sas (DS2246: 24 sas disks).
Should I divide my shelves into different stacks?
stack 1: 2 mixed shelves
satck 2: 1 sas shelf
What document describes the stacking rules?
Thanks,
Amir
1 REPLY 1
georgevj
Hi,
The solution you suggested looks good for me. Putting shelves into different stacks actually avoids single point of failure.
Mixing of SSD and SAS disks in the same shelf seems to be supported from ONTAP 8.0.1 onwards, but in ONTAP 8.1.1 , a bug is fixed w.r.t this. Details here: http://mysupport.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=542094
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Cannot find the answer you need? No need to open a support case - just CHAT and we’ll handle it for you.
