ONTAP Hardware
Controllers chassis fan speed too high
pedro_rocha
Hi, I am facing an issue with a FAS3240. The chassi fan speed is not normal and running above the limits (12Krpm). I was able to workaround it reseating all fans. But suddenly it all came back and the issue arose again. Has anyone seen this? I've saw twice on other FAS3200 controllers.
11 REPLIES 11
lmunro_hug
Hi,
Did you upgrade the SP recently? And did the fan speeds go to a higher RPM after a reboot/takeover?
brandon_odell
I just had it happen to me on a 3240 (sp reboot). I am running 1.2.3 on the SP. It appears to be a bug:
http://now.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=476392
pedro_rocha
Yeah man, that is really a bug. We should wait for the fix to be released
and in the meantime reset the fans when it happen again.
On Tue, Feb 21, 2012 at 10:20 PM, brandon.odell <
kramanella
Thanks All for the good info.
Fans reseated and the system is much calmer.
kramanella
I would also add, reseat each fan one at a time slowly. A message about the system shutting down in 2 minutes caused me a brief panic until the system figured out that all fans were still spinning.
stupendousman
You should always wait two minutes between two actions on FRU's, otherwise you would indeed receive this message.
ASTRAASIG
hallo
please, tell me, how do i reset only the fans? (i have the same problem with fan speed increasing on FAS3240)
thank you very much
MJSTONER2
Remove the front facia and you will see the Fans.
The Guidance I received was to remove a fan and wait 30 seconds before re-inserting the fan. Wait 30 seconds and repeat on other fans if necessary.
MJSTONER2
apparently the bug is fixed in 1.3 Hopefully I will find out soon.
pedro_rocha
Yes, but is it 1.3 out?
christin
Hi Pedro,
The public report of that bug has been updated:
http://support.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=476392
Also, SP 1.3 is now available for download
http://support.netapp.com/eservice/Firmware.jsp
Regards,
Christine
