ONTAP Hardware
how to reset only the fans on Fas3240?
CCOUNTERR
hallo
i have a problems with the fans , on FAS 3240.
from two days ago, they are working on a higher speed, and an exclamation led it is light orange, in front of the server case. (but the status of the heads it looks ok)
i read on other post that it is a bug, and a temporary solution it is to reset the fans.
my question is: how to reset only the fans?
thank you!
3 REPLIES 3
radek_kubka
Hi and welcome to the Community!
Have you seen this thread: https://communities.netapp.com/thread/20300?
Regards,
Radek
christin
Hi Bogdan,
I am investigating this and will see if there is a public report or KB article on this issue. If your issue is urgent, please open a case with NetApp Support.
Regards,
Christine
christin
Hi Bogdan,
The public report of that bug has been updated:
http://support.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=476392
Also, SP 1.3 is now available for download
http://support.netapp.com/eservice/Firmware.jsp
Regards,
Christine
