ONTAP Hardware
FAS2050 and SSD
JACKSIMONS
If I update the FAS2050-r5 to the latest flier software available for that hardware. Would it be possible to use this type of SSD? http://www.oczenterprise.com/ssd-products/talos-2-r-sas-2.5-mlc.html or the sata version.
I can't seem to find any detailed specification of the FAS2050. Do you know where I can find it? I would also like to know if I can upgrade the nic to 10gigabit.
Do you know if there are any plans to support the PCIExpress SSD technologies from ocz and similar manufacturers?
2 REPLIES 2
JACKSIMONS
Yes of course it is the same person. The reason I deleted the post was because my real name was showing. Then I changed the privacy settings and viewed from a different browser and my real name was no longer showing. Now you have posted my real name in a reply and I can no longer delete the thread.
aborzenkov
Well, I have deleted message.
