ONTAP Hardware
Converting a FAS2040 system in an HA pair to a disk shelf and attaching it to another system
ADDEDMARIORF3
Hello Team
It is possible to convert FAS2040 HA pair to a disk shelf to connect to FAS2520 system?
Thanks
-MRF
2 REPLIES 2
hariprak
Hi,
You can upgrade a storage system in an HA pair to a storage system in an HA pair in another family by replacing the
controllers and connecting the disk shelves
To upgrade the original nodes, you must follow certain guidelines and be aware of restrictions that affect the procedure
For more details, refer https://library.netapp.com/ecm/ecm_download_file/ECMP1151387
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
aborzenkov
The question was not how to reuse existing shelves, but how to convert FAS2040 into disk shelf. To my best knowledge it has never been supported for FAS2000, but I cannot find reference (FAQ does not mention it).
