ONTAP Hardware
DE6600 as JBoD
PurityControl
Recently bought NetApp DE6600 and I want to use it as JBoD connected to SuperMicro Server. Can this controller be used?
NetApp X3149-R6 NVRAM8R Dual Port Pci-E Controller 110-00274+B0
I was wondering what can I do to manage this?
Any help will be appreciated.
1 ACCEPTED SOLUTION
paul_stejskal
You may find more support in /r/techsupport (not really /r/netapp) on Reddit. I'm not sure if that will work, but I think one is from FAS. You list two different parts there I believe. The X3149 is a PCI-e card that NVRAM is added to it looks like. I don't think this will work, but you will need a SAS HBA to connect (from what I've seen). I've never tried this and have zero experience.
2 REPLIES 2
paul_stejskal
PurityControl
Thanks.
Yes it seems that it needs SAS HBA controller.
I'm not sure which one is right though asI need low profile one.
I have read few things and they have managed to do JBoD through Fibre Channel as well.
