ONTAP Hardware
Data Ontap Controller rebooting, no log
edolinares
Hello Guys, i had an issue with the controller of a FAS3210... since day A reboots, 1,2,3, times then took longer to boot. After review one of the power sources fails, but i understand that should still work with the second one right?
Now if we shut it down it works 1 hour then 3-4 reboots and no came back.
Connected to the terminal does not show issues, the only alert is the missing PSU, from the manager also no loggs or alerts.
Ideas?
1 REPLY 1
paul_stejskal
I'd open a case as we would need to collect logs and figure out what is going on if you have valid entitlements.
