ONTAP Hardware
Difference between sum aggregat
olivev
Hi all,
i have a difference between the sum of the result of the command below:
> agg show_space -g
Aggregate                       Allocated            Used           Avail
Total space                       40511GB         40057GB          1209GB
Snap reserve                          0GB             0GB             0GB
WAFL reserve                       4635GB           490GB          4145GB
Used + Avail = 40057 +1209 = 41266 Go  not 40511Go !
do i have really 1209Go free
or do i have (40511 - 40057) = 454Go free
do i have really 1.2T free with this command df -A ?
> df -A
Aggregate               kbytes       used      avail capacity
aggr0               43750651392 42484493040 1266158352      97%
aggr0/.snapshot              0          0          0     ---%
3>
regards
1 REPLY 1
deepuj
Hi,
I think this KB will help you unserstand the difference.
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
