ONTAP Hardware
Disk Shelf ID Physically Set to 2 but showing as shelf ID 175 in OnTap?
dartfordbc
Hi
We just added a new shelf of DS4243 to our FAS3210C.
When I connected the shelf up I didn't realise the Shelf ID was still flashing. I then did a 'disk assign all'.
When I look in the filer (using OnCommand System Manager) now it shows the disks as being having Shelf ID 175.
Have I made a mistake? is this OK?
Thanks
3 REPLIES 3
SeanLuce
You can change the shelf ID at any time.  Your aggregates will still be recognized and come back online as if nothing happened.
SeanLuce
cf disable
Halt both controllers
Power off the controllers
change the shelf ID
power cycle the shelf
power the controllers back on
cf enable
dartfordbc
Ahh OK I understand. Thanks for the help!
