ONTAP Hardware
Disk replace with different capacity
LORENZO_CONTI
Hello,
maybe this is a trivial question, but I need some advice from experts 😉
I have to replace 2TB ATA disk with 2TB SATA (BSAS on DS4246) disk, on a FAS system in HA (8.3.2 cluster mode), the aggregate is a flash pool.
I would like to not relocate controller, I want to do it non disruptively, and I have 3 spare DS4246 with 3TB drives.
I will leave doing vol move as last option.
Here's what I want to do:
- disk replace 2TB ATA on 3TB BSAS
- disconnect 2TB ATA, connect 2TB BSAS
- disk replace 3TB BSAS on 2TB BSAS
Is it possibile to do this?
Thank you very much
1 ACCEPTED SOLUTION
AlexDawson
3 REPLIES 3
AlexDawson
Hi,
This is supported. This article outlines pretty much the exact scenario you're asking about - https://kb.netapp.com/support/s/article/ka31A0000008gtZQAQ/how-to-add-larger-capacity-disks-to-a-raid-group-that-contains-smaller-capacity-disks?langu...
Good luck!
LORENZO_CONTI
Hi Alex,
I found 2 conflicting bug because I'm not sure about how parity disk will be handled.
https://mysupport.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=108147
https://mysupport.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=155069
Maybe the higher id will be right...
I'm stil considering vol move as a good option 😉
AlexDawson
Both of those BURTS have been resolved and the functionality should work as designed
