ONTAP Hardware
Exchange 2010 Best Practice
JOHNYTHENMARRY
  Hi,
I have to migrate the Exchange 2010 database to FAS2040 and the capacity of the DBs is almost 1.5 TB including the logs. So which option I should choose from the below
  1. Create a 1.5 TB Volume and create multiple LUNs with in the same volume
  2. Create one Volume per LUN
Thanks
Johny
1 REPLY 1
peter_lehmann
Hi John
According to Best Practices, create one volume per LUN.
Search for the related article online at: www.netapp.com/us/library and then look for TR-3044.
Peter
