ONTAP Hardware
FAS 2240-2 second Backup Device
grenadier3107
Hi,
a customer has a FAS 2240-2 with a single path connected SAS-Shelf and one backup device on the other SAS-Port. Is there a supported configuration for a second SAS backup device on a stand alone controller?
I think to plug in the second backup device into the disk shelf is not supported but is it technicallly possible? DataOntap recognise the 2. IBM Drive (sysconfig -t) but when I run a dump command I get the error "invalid tape drive"?
Is there another way to connect a second backup device? (possibly with sas switch?)
regards
gren
1 ACCEPTED SOLUTION
YIshikawa
As described in KB 2018848, you can not mix tape device and disk shelves in same adapter.
https://kb.netapp.com/support/index?page=content&id=2018848
In my understanding, 3rd party SAS expander is not supported. Only configuration I think of is purchasing FC HBA and FC tape devices.
2 REPLIES 2
YIshikawa
grenadier3107
Thank you for the link. For the 2240 there is a FC-Mezzanine Card X1150A-R6 with two 8Gbit Ports.
Ok, this is fine. It's better than no solution.
