ONTAP Hardware
Snapmirror shedule wont work.
SCOTT_V_RONTALE
Hi Everyone ,
 I have scheduled a date for snapmirror but it dont trigger or works for the specific time i have created. Setup is a back-to-back network of two netapps. Everytime i check the lag the time is too high so meaning the schedule for snapmirror didnt work. I can ping each netapp and i have created a baseline copy for it. .
Please help
192.168.254.190 = e0b of first netapp
192.168.254.191 = e0b of second netapp
192.168.255.1 = e0c of first netapp
192.168.255.2 = e0c of second netapp
Here is the schedule of the snapmirror.conf :
192.168.254.190:agentvolicount_1 192.168.254.191:agentvolicount1_1 - 0-55/5 * * *
192.168.254.190:agentvolidata_1 192.168.254.191:agentvolidata1_1 - 15 * * *
192.168.254.190:agentvolnsb 192.168.254.191:agentvolnsb1_1 - 15 * * *
192.168.254.190:agentvolmwsqdb1 192.168.254.191:agentvolmwsqdb1_1 - 15 * * *
192.168.254.190:agentvolmegaportal_1 192.168.254.191:agentvolmegaportal1_1 - 15 * * *
192.168.255.1:agentvolistorage 192.168.255.2:agentvolistorage1_1 - 15 * * *
192.168.255.1:agentvolsapdbprod 192.168.255.2:agentvolsapdbprod1_1 - 15 * * *
192.168.255.1:agentvolipayV2 192.168.255.2:agentvolipayV2_1 - 15 * * *
Here is the snapmirror status:
snapmirror statusSource Destination State Lag Stat
192.168.254.190:agentvolicount_1 Isite:agentvolicount1_1 Snapmirrored 01:19:56 Idle
192.168.254.190:agentvolidata_1 Isite:agentvolidata1_1 Snapmirrored 03:05:45 Idle
192.168.255.1:agentvolipayV2 Isite:agentvolipayV2_1 Snapmirrored 02:52:04 Idle
192.168.255.1:agentvolistorage Isite:agentvolistorage1_1 Snapmirrored 02:42:43 Idle
192.168.254.190:agentvolmegaportal_1 Isite:agentvolmegaportal1_1 Snapmirrored 02:31:46 Idle
192.168.254.190:agentvolmwsqdb1 Isite:agentvolmwsqdb1 Snapmirrored 02:25:26 Idle
192.168.254.190:agentvolnsb Isite:agentvolnsb1_1 Snapmirrored 02:21:57 Idle
192.168.254.190:agentvolsapdbprod Isite:agentvolsapdbprod1_1 Snapmirrored 02:17:20 Idle
Thanks,
Scott
1 ACCEPTED SOLUTION
aborzenkov
snapmirror status lists local filer name (at least I assume it is filer name) and snapmirror.conf lists file IP. I suspect that causes snapmirror to skip these entries.
3 REPLIES 3
aborzenkov
SCOTT_V_RONTALE
I'll try to change it. Ill update you asap. thanks
SCOTT_V_RONTALE
It work sir. Thank you!!
Spoiler
Spoiler
Smiley Very Happy
