ONTAP Hardware
FAS 8040
MJABER
hi all ,
we would like to get new FAS8040 system and we need to have the  below disk type :
  • SSD
  • SAS
  • SATA
is their any recommendation or concern if the above going to be implemented  ?
is there any tier license from netapp required for such scenario .
thanks all
2 REPLIES 2
Sahana
Hi,
Yes, You can use mixed configurations. Refer Storage Subsystem Resiliency Guide Mixed Configurations on page 14, Data-Availability Tiers page 15.
The base license would allow you to add these drive types.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Ashun
hi
SSD, SAS, SATA types of disks can be used, in HWU to confirm the support of each type of disk PN
More attentionWhat are the maximum drives and shelves limits in a mixed ONTAP shelf stack - NetApp Knowledge Base
