ONTAP Hardware
FAS Controllers without SAS Ports
OmotayoZadok
Are there FAS Controllers without SAS Ports to connect a Disk Shelf?
I have a FAS2520 here, And I can't find any port to connect a new disk shelf I just bought. Disk Shelf is DS224C.
is this normal?
1 ACCEPTED SOLUTION
Fabian1993
Hi @OmotayoZadok,
this is your System (2520 Chasis), the Red ones are the SAS Ports, you have to bought a QSFP to Mini SAS HD Cable to connect your Shelf.
1 REPLY 1
Fabian1993
Hi @OmotayoZadok,
