ONTAP Hardware
FAS Fibre Channel HBA Trunking
ploufg
Hi
With the virtualization of the Data Center, shared infrastructure, and private cloud computing.
I wonder if the FAS6200 series support Fibre Channel HBA Trunking on the controller for higher bandwidth performance.
Thank you
1 ACCEPTED SOLUTION
ostiguy
Through fc zoning, you can restrict which storage ports the host HBAs can get to - this has performance implications.
If you only ever zone your qa hosts to ports 0a and 1a, while your esx hosts are zoned to 0b and 1b, you do not need to worry about storage port contention between your qa and esx hosts.
3 REPLIES 3
baijulal
Please refer to http://community.brocade.com/message/4357
Basically if you are trying to address bandwidth issue, you can have multiple target ports, using zoning / port sets on storage to do proper load distribution.
aborzenkov
Load distribution is implemented by host multipath software. I am curious how zoning and/or port sets are related to it ☺
ostiguy
