ONTAP Hardware
FAS factory default
tclark
I'm trying to reset an FAS 2520 to factory default but I can't see the device boot sequence in order to press CTRL C. I'm using putty with a KeySpan high speed USB to serial adaptor. It connects with com4 but never prompts to login and I can't see anything happening during power up. Once it's up I have no trouble getting in by SSH. Any ideas?
4 REPLIES 4
aborzenkov
You can access console via SP session (system console).
tclark
I'm not familiar with how to do that. Can that be done via putty?
aborzenkov
Yes. You need to setup SP IP address (that is normally done from within running Data ONTAP) and then connect with SSH to this address. Physical connectivity is over wrench port.
Naveenpusuluru
Hi @tclark
Please use the below command to check the SP ip.
 system service-processor show
You can use the service processor to connect to the console remotely.
