ONTAP Hardware
Additional shelf to 2554
avinchakov
Hi folks,
I have a FAS2554 HA system in production with internal shelf with SATA disks. Connection as in a manual:
I want to add a new additional shelf DS2246 with SSD disks, but I don't understand some moments. In a manual it is written:
1) I can hot-remove SAS cables?
2) On the picture connection of the full stack. How to connect only one shelf I don't understand.
3) I shall switch off ACP before?
4)
the correct scheme will be?
Thank you!
1 REPLY 1
GERA_SUKHOV
On the last picture there is no cable connecting the ADC channel connected between the modules of the shelf. The rest of it right.
