ONTAP Hardware
FAS2020 - Quick question on power to controllers
UNDECIDED
Hi all, just a quick question on the power going to the chassis, does each power cable provide power to an individual controller or to both? I.E if I take one of the two power cables out, will one controller cease to work?
If they are individula, then which one controlls which controller? Left power for top controller?
thanks
1 ACCEPTED SOLUTION
aborzenkov
Power supplies are shared and redundant. It will continue to run with one PS for both controllers.
2 REPLIES 2
aborzenkov
UNDECIDED
Thanks for the quick response!
