ONTAP Hardware
FAS2040 to FAS8020 Migration
darobbins
We are going to replace at 2040 with an 8020, however we cannot do a typical head swap due to code levels that cannot be reconciled.
Is it possible to add the current disk to the new system?
Will this cause an issue with the data?
Will it automatically upgrade the label version or will it not be able to read the disk?
1 ACCEPTED SOLUTION
darobbins
Was able to test using like hardware and software versions, everything went fine.
3 REPLIES 3
darobbins
SERGEHOEDTS
Hello,
Could you describe briefly your actions ?
I have to do same migration and i can't find a lot of informations.
Thanks a lot
Serge
darobbins
The case that I had was a FAS2040c with interal 450GB SAS and two shelves DS4243 2TB, and a FS2040 stand alone (no partner) with one shelf DS4243 1TB.
After fully building up the new system, FAS8020 running 8.2.1, I shutdown the stand alone FAS2040 system, brought it up in maintenance mode, removed disk ownership, offlined current aggr0, hot added the 1 shelf of 1TB disk to the FAS8020, and assigned ownership.
I did NOT get any messages about version mismatch nor did it state that it actually changed anything, it did automatically rename the aggr0 to aggr0(1) which was no big deal.  But i never ran into any other issues.
Performed the same sequence on my other FAS2040 system with the exception that I needed to take care to assign the appropriate disk to the appropriate controller; halt systems, boot maintenance mode, offline all aggregates, use the 'disk reassign -s XXXXXX -d XXXXXX' (did last step while attached to old system).
I did need to recreate my CIFS shares, create aliases and SPNs respectively.
As a side note the internal 450GB SAS drives were just used for VMFS so those VMs were storage migrated between the two systems.
