ONTAP Hardware
FAS2050 Shelf Options
stevemagginetti
I currently have a FAS2050 with two heads running DataOnTap 7.3.5.1P4.  It's connected to a DS14-AT shelf.  We're at a point where we're going to need more storage, but might not have enough capital for a new controller, so I'm looking around for DS4243 shelves.  I know that this is a SAS shelf that will need a new HBA on our controllers.  My question is if I can run both the DS14 via SFP fiber and the DS4243 via SAS at the same time.  My intention would be to eventually move everything off the DS14 entirely, given I can make the DS4243 big enough.
Also, is there a specific part number for the SAS HBA?  I can't seem to find any on the Netapp website.
1 REPLY 1
andris
Hi Steve,
You'd be looking for this HBA for your FAS2050's:
2p 3Gb SAS, PCIeX2062A-R6
You'll need MiniSAS-QSFP cables for controller to shelf connections.
Part NoBeginEndLengthDescription
X6543A-R6miniSASQSFP2mCable,miniSAS Cntlr-Shelf,2m
X6544A-R6miniSASQSFP5mCable,miniSAS Cntlr-Shelf,5m
The Hardware Universe is a handy place to look all this up.
http://hwu.netapp.com
I'd upgrade your systems to 7.3.7P2 for the best stability and performance.
