ONTAP Hardware
FAS2220 Processor?
ricardoduarte
Hi there,
Does anyone can share the model of the processor inside the FAS2220?
Is it the same as the one on FAS2240?
Thanks.
5 REPLIES 5
scottgelb
The spec I saw was 2x 64-bit (8 with hyperthreading) for both 2220 and 2240... same controller module just different max spindles (60 compared to 144) and mezz card for FC or 10GbE on the 2240 (but heard we may get a mezz card option on the 2220 for ethernet).
ricardoduarte
So, this looks like the same PCM.
Why the different spindle counts? Different SAS controllers?
Should, for the same number of spindles, the FAS2220 perform the same as a FAS2240?
scottgelb
It has a different chassis… looks like the same PCM… the chassis for 2220 is a different drive type. Performance should be the same for the same spindle count.
ricardoduarte
Any idea how many SAS lanes are available?
scottgelb
6Gb port has 4 lanes. 24gb on each connection to 6Gb IOMs. If a 3gb ds4243 stack it would auto negotiate to 3Gb / 12Gb on 4 lanes.
Sent from my iPhone 5
