ONTAP Hardware
Configuration check of a storage system
TOBIAS1979
Hi
We have moved a storage system (3210 + 2xDS42XX from one datacenter to another. Now
we have connected it as it was before, and started it up and everything seems ok. But there
should be some kind of configuration check that can be run on the system to see
that everything is configured correctly. Where can I find it or information about it?
Rgds
T.
2 REPLIES 2
shane_bradley
wireguage/ config advisor is what you're looking for. Downloadable from the toolchest on the supportsite
TOBIAS1979
Thanks, Shane
