ONTAP Hardware
FAS2240-4 fully populated with 4TB drives - what is amperage requirement
jrigg
Needing to relocate FAS2240-4 and have to provide input power requirements.  Power will be 110V.  Anyone know the required Amps?  Documentation talks about amps in relation to heat dissipation - just want to make sure I am figuring the totals correctly.
1 ACCEPTED SOLUTION
AlexDawson
Hi there,
FAS2240-4 with 24 x 4TB SATA drives at 110V would be 5.5A Typical, 6A worst case, and output 1,855BTU typical, 2,022 BTU worst case
2 REPLIES 2
AlexDawson
Hi there,
andris
In the spirit of "teaching to fish"...  this type of info is available in the Hardware Universe.
Select the platform, display the results, look at the Size, Weight, Acoustic, Power table.
