ONTAP Hardware
FAS2240-4 power sequence
DOLPHIN168
Hi,
Is there a power sequence to power up and power down FAS 2240-4?
Thanks in advance.
1 REPLY 1
RPHELANIN
If there are shelves that contain the root volume then they need to be powered on first
If it is internal disks only then there is no specific sequence.
