ONTAP Hardware
FAS2240 Configuration Question
JFGANTECH
I have found conflicting information regarding the possibility of connecting a single DS2246 shelf and a single DS4243 disk shelf to a FAS2240-2. If this is in fact a valid configuration I would be interested in locating infromation on how to cable SAS and ACP connections.
6 REPLIES 6
vmsjaak13
Hello,
this is supported.
SAS and ACP cabling rules and examples can be found in the Universal SAS and ACP cabling guide: https://now.netapp.com/NOW/knowledge/docs/hardware/filer/215-05500_B0.pdf
Regards,
Niek Baakman
JFGANTECH
Hi Niek
Thank you for your quick and helpful response. This is exactly what I was looking for.
Rick Falter
MCSE, VCP, NetApp NCDA, NCIE-SAN
Systems Engineer
radek_kubka
Hi and welcome to the Community!
It is supported, indeed
Have a look at this doc, p16:
https://fieldportal.netapp.com/ci_getfile.asp?method=1&uid=7178&docid=37324
Yes, you can mix DS2246 and DS4243 on the single FAS2240 SAS stack but you should minimize transitions between the two shelves types. It should be noted mixing DS2246 and DS4243 is only supported on FAS2240 and no other platforms.
Regards,
Radek
JFGANTECH
Hi Radek -
Thank you for your quick and helpful response. I am not certain what is meant by "you should minimize transitions between the two shelves types". Possibly they are suggesting that like shelf types should be cabled together if there will be multiple shelves of both types ? The transition being a connection of a 2246 to a 4243 ?
Thanks
Rick Falter
Systems Engineer
radek_kubka
Yep, this is my understanding as well.
To make things more interesting, NetApp also recommends to have as few as possible cross-over points (i.e. changes from SAS to SATA technology) in a mixed SAS/SATA stack . Again, no hard numbers are provided, so in theory any combination is supported.
JFGANTECH
Also good to know. Thanks !
Rick Falter
Systems Engineer
