ONTAP Hardware
Shut down the FAS systems (with disk sheves) using script
saravanp
Hi Team,
I am just wondering , is there any way we can put some scripts from RLM or in controller itself, to shutdown the entire storage stack (controller , disk shelves)
instead if doing it manually ...
Thanks in advance
1 REPLY 1
aborzenkov
There is no documented way to switch off disk shelves. They (unfortunately) remain powered on even if system shuts down as result of overheating.
