ONTAP Hardware
FAS2520 Cluster from 2 standalone 2520 w single controller for NFS
tpeter
Dear Professionals,
I have 2 FAS2520s, all with sigle controllers.
Is it possible to create a node Cluster from them (switchless maybe)?
There are 12-12 identical discs in each of them2.
I would use them for NFS.
Thanks for your answers,
_Peter
1 ACCEPTED SOLUTION
AlexDawson
Oh sorry! Someone asked the same question in there at about the same time.
Do you want data in place?
Assuming no - boot each node up to maintenance mode, using the special boot menu (control-c when prompted) and run this on each node:
ha-config modify controller ha
ha-config modify chassis ha
Then reboot and run option 9a from each system, then reboot and run option 9b from the system that says "LOADER A>". It will then prompt you to setup ONTAP again. You will need to re-enter the license details at this time.
Hope this helps.
6 REPLIES 6
AlexDawson
Hi, I'm guessing this has been answered on Discord. Please let us know if you need any further assistance 🙂
tpeter
Thanks for your answer.
Can you help me out with a link or reference, I am not using Discord yet.
Thanks in advance,
_Peter
AlexDawson
Hope this helps.
tpeter
Thanks Alex
Does it mean, that the 2x12 disks will be visible in the Cluster, and can be used to create aggregates and maybe a single big volume (Now we have 2x12x2TB disks in them)
AlexDawson
Yes - they will be partitioned first, to create boot partitions, but there will be a small root/boot partition and the remainder available for storing data on.
tpeter
Thanks!
It make sense.
