ONTAP Hardware
FAS2750 Monitoring of power supply via SNMP
GreenHornP
Hello,
I have issue with monitoring via SNMP. We had issue with power supply, but alert didn´t start. So when I analyze issue, all seems right in monitoring.
OID seems correct
1.3.6.1.4.1.789.1.21.1.2.1.15enclPowerSuppliesFailed
But when I try snmwalk, so output seems empty.
SNMPv2-SMI::enterprises.789.1.21.1.2.1.15.1 = ""
I'm not sure what should be in parentheses when there's a power problem.
Can anyone advise me what is wrong and how can I fix this problem?
Thank you very much
1 ACCEPTED SOLUTION
andris
The .1 after .15 is the shelf ID number. Is the FAS2750 enclosure shelf "1"?
"" (null) = neither PSU is failed.
1 = PSU1 is failed.
2 = PSU2 is failed.
2 REPLIES 2
andris
1 = PSU1 is failed.
2 = PSU2 is failed.
GreenHornP
Thank you for response. I test it and all is running. And I found next possible OID -
.iso.org.dod.internet.private.enterprises.789.1.2.2.25.0
OCTET STRING - The system's global status is normal.
It is good basic overview.
