ONTAP Hardware
FAS2820 Mezzanine replacement with a different Mezzanine
Yuriy_Vorobkevych
Hi everyone,
The customer bought FAS2820 with Mezzanine card X1166A-C (by mistake), which is not possible to insert SFP 1Gb RJ45. Now we ordered X1170A MEZZANINE,4x10G BASE-T. Is it possible to replace Online with standard Mezzanine replacement procedure existing cards by new cards?
https://docs.netapp.com/us-en/ontap-systems/fas2800/pci-cards-and-risers-replace.html
Best regards,
Yuriy Vorobkevych
Tech consultant
1 ACCEPTED SOLUTION
andris
I'm not sure what you mean by "online".
However, you can certainly use the mentioned procedure to change the mezzanine module (slot 1) from one type to another, as well.
1 REPLY 1
andris
