ONTAP Hardware
FAS3240 - Ontap 8.1.3P3 7-Mode - Correctable Machine Check Error at CPU
dbo
Hello,
We are facing to a strange situation. We have a FAS3240 in Multi-Path HA on Ontap 8.1.3P3 7-Mode.
We can see, at console, a lot of error messages “Correctable Machine Check at CPU2. MC3 Error…” and “Correctable Machine Check at CPU3 MC3 Error…”
Strange: These message are not recorded in “/etc/messages”! Why?
Other strange point: At “sysconfig –M” we can see 2 DIMM in slot 1 and 3 but they are physically installed in slot 1 and 2 (good configuration). By cons the 8192 MB are well seen.
!DIMM-NV1!94-01-1118-00000F0F!SG572564CNG535P1SF!
!DIMM-NV2!94-01-1221-00000D30!SG572564CNG535P1SF!
!DIMM-1!94-01-1118-00000ECA!SG572564CNG535P1SF!
!DIMM-3!94-01-1221-00000D19!SG572564CNG535P1SF!
Thanks in advance for your help.
Regards,
DBO
3 REPLIES 3
rh
DBO,
What does the  command "memerr" show (you will need to "priv set advanced" first)?
Richard.
asulliva
(Full disclosure, I'm not a hardware or support person, but I have stayed at a Holiday Inn Express before)
It appears to be a hardware issue.  If you haven't already, open a support case...they will troubleshoot and replace the part if needed.
Andrew
If this post resolved your issue, please help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
dbo
Hello Richard, Andrew,
Thanks for your fast answer.
Unfortunately the memerr report no error. I already replaced the 2 DIMM to eliminate a potential memory issue but the problem persist.
Regards,
Dbo
