ONTAP Hardware
FAS3240 - Upgrading from 8.1 to 9.x
netapptecdom
Hello community,
I want to know how can I upgrade my version for FAS3240 from 8.1.3 to latest 9.x stable version available supported to this NetApp.
Is disrruptive process?.
Please, let me know.
Regards,
1 ACCEPTED SOLUTION
SeanHatfield
If you are running in 7-mode, the terminal release is 8.2.5P1.  If you are running in cluster mode, you can upgrade that model to 8.3.2P12.   It is not capable of running any ONTAP 9.x release.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
3 REPLIES 3
Damien_Queen
What ONTAP do you have, is it 7-mode or cDOT?
If it's cDOT, you can upgrade nondisruptively.
SeanHatfield
andris
Sean is right on...
If you enable AutoSupport, you can find out exactly how to upgrade to the latest possible ONTAP release with Upgrade Advisor in the NetApp Active IQ web portal.
