ONTAP Hardware
FAS8040 Ontap 9 Data network settings
marcinmf
Hello,
We have a cluster with 2 FAS8040 nodes running ontap 9.2
both nodes have dula 10GB port cards with links to our main switch dual Cisco Nexus 7K
Is thre some documentation about best practicess on connecting / conconfiguring port groups on the Cisco side?
Thanks.
Martin
1 ACCEPTED SOLUTION
andris
1 REPLY 1
andris
The additional information section of the ONTAP® 9.0 NFS Configuration Power Guide has a bunch of great resources to check out.
Specifically:
NetApp Technical Report 4182: Ethernet Storage Design Considerations and Best Practices for Clustered Data ONTAP Configurations
