ONTAP Hardware
Flash Pool aggregates with Storage Encryption
marcinmf
Hello,
We have dual FAS8040 running Ontap 9.2
Have all drives that are self encrypting where 12 of them are 800GB SSD and 64 of 1.8 TB 10k rpm drives.
Looking online the self encryptong drives can not be used for flash pool agregates
https://library.netapp.com/ecmdocs/ECMP1196986/html/GUID-B347C746-FD91-484D-8BA6-A23D7C05EABE.html
On another article it says that 800GB SSD can be used are are self encrypting
https://community.netapp.com/t5/Technology/New-800GB-NSE-SSD-Expands-FAS-Security-Options/ba-p/91371
Can we use 800 GB SSD drives for Flash Pool aggregate on FAS8040 systems runnign Ontap 9.2?
Thanks,
Martin
1 ACCEPTED SOLUTION
marcinmf
I can answer my own question here.
It is possible to do this.
Here is great guide
https://library.netapp.com/ecm/ecm_download_file/ECMLP2572742
It is possible to create Flash Pool aggregates with SEDs running ontap 9.2 and using 800GB SSD drives.
1 REPLY 1
marcinmf
Here is great guide
