ONTAP Hardware
FAS8040 power consumption
FAS8040power
Good day, does anyone knows where I can find the maximum power consumption of a FAS8040?
1 ACCEPTED SOLUTION
JamesIlderton
Hardware Universe is the place you want to look (https://hwu.netapp.com/), and you'll need to add the disk shelves up as well from there.  Alternately, NetApp SEs and partners can build out your system in Synergy and it has lots of good output, including the full power usage.
2 REPLIES 2
ekashpureff
Power consumption for controllers and drive shelves is listed in Hardware Universe.
http://hwu.netapp.com/Home/Index
On a FS8040 it sez 8.76A@100V ...
I hope this response has been helpful to you.
At your service,
Eugene E. Kashpureff, Sr.
Independent NetApp Consultant http://www.linkedin.com/in/eugenekashpureff
Senior NetApp Instructor, FastLane US http://www.fastlaneus.com/
(P.S. I appreciate 'kudos' on any helpful posts.)
JamesIlderton
