ONTAP Hardware
FAS8060 and DS2246 Watt Values
JeremyDriscoll
What are the values for the "Nameplate Watts" and "Budget Watts" for the power supplies on the NetApp FAS8060 and DS2246?
2 REPLIES 2
DJ-Potsdam
Hi,
How are you?
I hope you can find this values under "Size, Weight, Acoustic, Power" in the hwu.netapp.com once you select the platform and version of ONTAP. For disk shelf you can run a seperate query under "Shelves"
Thanks
Ashun
hi,
If you want to know the information, the following steps may be useful for you
Additional information can also be found in HWU
A、 Look for FAS8060 Watt Values in HUW
1, select the FAS8060 platform and your current version to view the results
2. Find the corresponding information in See Powers by configuration
B、 Look for DS2246 Watt Values in HWU
1. Select your current version and check DS2246 to see the result
