ONTAP Hardware
FAS8080 Controllers
TTS
 the controller on the FAS 8080 Systems, is there such thing as protocol keys as part of the controllers? Supposedly, when you replace a controller and do not include the protocol keys on the controller, it will not function. This first time I am hearing of such. Can someone give insight on this? Thanks in advance
1 ACCEPTED SOLUTION
3 REPLIES 3
Ontapforrum
Well, there are license keys for 'protocols" (ex- CIFS/NFS/ISCSI/FC etc). Also, could you elaborate on - "it will not function" ? What do you mean here.
I haven't done replacing controller myself so can't answer this question, but as I read :
You must install new licenses for the replacement node if the impaired node was using ONTAP features that require a standard (node-locked) license.
https://library.netapp.com/ecm/ecm_download_file/ECMP1199896
I guess someone in forum will correct me here.
paul_stejskal
The license keys should be recreated. A non-technical case is made when a motherboard is replaced in a RMA, so this should update the internal system. I believe the license keys if needed are part of this. If you have any problems you can contact the support engineer and/or account team.
