ONTAP Hardware
FAS9000 MetroCluster IP - Switch, SFP, & Cable Requirements
JKW4
Need Guidance Please...
I am hoping to transition an existing customer from a FAS9K Switchless Fabric MetroCluster to a MetroCluster IP Solution.
  • The existing MetroCluster HA Pairs are switchless(i.e. do not include Cluster Interconnect Switches).
  • The new MetroCluster IP will have the following storage attached per side....
    • 2 x DS224C w/24x7.6TB SSDs
    • 1 x DS460C w/30x10TB 7.2K NL-SAS HDDs
I am trying to determine exactly what Parts/Pieces I need to configure to accomplish the transition.
To be quoted...
FAS9000 Internal
  • Can HA Pair Cluster Interconnect remain switchless?
    • If not, what internal ports, NICS and SFP's must be included?
  • Can I/Should I use the MetroCluster IP Switches as the HA Pair Cluster Interconnect?
    • If so, what SFP's and Cables must be included?
MetroCluster IP
  • I believe that I need 4 x Cisco N9336C FTE 36 Port Switches - PN# X190210-FE-PE
  • How many 100GbE ISL QSFPs do I need?  What PN#?
    • Cables? PN#
What am I missing? Not thinking of?
Thanks,
Joe W.
1 ACCEPTED SOLUTION
1 REPLY 1
