ONTAP Hardware
FC card offline - how can I bring it online
JBGood
Dear all,
I have a FAS3220 runing NetApp Release 8.2.5P1 7-Mode. Slot 2 in the controller has a QLogic card in it but the card is offline:
slot 2: Fibre Channel Target Host Adapter 2a
(QLogic 2532 (2562) rev. 2, <OFFLINED BY USER/SYSTEM>)
Board Name: QLE2562
Serial Number: BFD1248F51482
Firmware rev: 5.8.0
Preload Rev: 3.3.2
Host Port Addr: 000000
FC Nodename: 50:0a:09:80:88:d1:d5:03 (500a098088d1d503)
FC Portname: 50:0a:09:81:88:d1:d5:03 (500a098188d1d503)
Connection: No link
Switch Port: Unknown
SFP Vendor Name: FINISAR CORP. (Warning: SFP info not updated when port is OFFLINE)
SFP Vendor P/N: FTLF8528P3BCV-QL
SFP Vendor Rev: A
SFP Serial No.: PNB3X2F
SFP Connector: LC
SFP Capabilities: 2, 4, 8 Gbit/Sec
I/O base 0x00000000ffffff00, size 0x100
memory mapped I/O base 0xded00000, size 0x4000
The card show up in the ucadmin command:
FAS3220> ucadmin show
Current Current Pending Pending Admin
Adapter Mode Type Mode Type Status
0c fc initiator - - offline
0d fc initiator - - offline
2a fc target - - offline
2b fc target - - offline
3a fc initiator - - offline
3b fc initiator - - offline
3c fc initiator - - offline
3d fc initiator - - offline
How can I bring the card online again ?
Best regards,
Johnny Begood.
3 REPLIES 3
donny_lang
Can you bring it online with the "storage enable adapter 2a" command?
https://library.netapp.com/ecmdocs/ECMP1196986/html/GUID-2214EC11-155A-4748-B7B9-9F5AA2D34E5B.html
JBGood
Donny,
Thanks for your reply. The problem is that FC adapter 2a is not visible in the output of 'storage show adapter'. So maybe I need a deeper level in the NetApp firmware to enable the adapter. Do you have an idea ?
Best regards,
Marc.
OldSkewl
Our issue with a QLogic 2432 was the "type" wasn't specified: "fcadmin offline <card>" fcadmin config -t target <card>", reboot. Yours does show the type but I thought this mnight lead you somewhere in troubleshooting. Cards still don't show in "storage show adapter" for whatever reason but they do function and show in "sysconfig -a". We have V3240's with 8.2.2 in a lab
