ONTAP Hardware
Failover FAS6030 - Two controllers with CPU average consumption on 82%
DLAC1985
My friends,
I have two controllers FAS6030 with CPU average consumption on 82%.
It is correct to say that in a failover event in my environment would not be possible?
Thanks
Daniel
1 REPLY 1
JGPSHNTAP
What ontap version are you running.  Also, are you looking at just sysstat or sysstat -m 1
Once I hear those answers I can better answer, but on the surface you can failover, but you will experience what is called performance degradation HA.
