ONTAP Hardware
Flash Pool SSD on FAS3240
kwana
Hi,
Can FAS3240 support flash pool with 3 SSD only?
Thanks
Alex
5 REPLIES 5
SEANTRACY
My understanding is you need the same amount of SSD's on each head of a HA pair.
aborzenkov
No, you do not. Same as you do not need the same disk configuration
Отправлено с iPhone
28.12.2012, в 20:04, "Sean Tracy" <[email protected]<mailto:[email protected]>> написал(а):
<https://communities.netapp.com/index.jspa>
Re: Flash Pool SSD on FAS3240
created by Sean Tracy<https://communities.netapp.com/people/SEANTRACY> in Products & Solutions - View the full discussion<https://communities.netapp.com/message/97446#97446>
Reply to this message by replying to this email -or- go to the message on NetApp Community<https://communities.netapp.com/message/97446#97446>
Start a new discussion in Products & Solutions by email<mailto:discussions-community-products_and_solutions@communities.netapp.com> or at NetApp Community<https://communities.netapp.com/choose-container.jspa?contentType=1&containerType=14&container=2068>
kwana
Thanks,
Sorry for misleading,  I mean each controller have 3 SSD disks for flash pool, can 3240 HA support this flash pool configuration
(1 data + 2 Parity)?
Alex
SEANTRACY
It does support it. That is the configuration I was thinking of. The SSD’s don’t need a spare as I understand it.
SEANTRACY
Hi, Thanks. I do have a config question. This is my first time using SSD’s NetApp setup the filer with half the SSD’s on one controller and half on the other. I am trying to figure out if I should keep all the SSD’s on one controller or spread them across two?
