ONTAP Hardware
Get SFP specific details using powershell
vishwand
team,
i am looking for some tips to find SFP details(vendor, partnumber,serialnumber ) using powershell. any tips or ideas
1 ACCEPTED SOLUTION
jcolonfzenpr
Hi,
You can use the Get-NcFcpAdapter command:
Get-NcNode | Get-NcFcpAdapter | Select-Object node,Adapter,portname,SfpPartNumber,SfpSerialNumber,SfpVendorName
Here are all the properties of the cmdlet:
Adapter                                        MaxSpeedSpecified                              SfpEncoding
CacheLineSize                                  MediaType                                      SfpFcSpeedcapabilities
CacheLineSizeSpecified                         MpiFirmwareRev                                 SfpFormfactor
ConnectionEstablished                          NcController                                   SfpPartNumber
DataLinkRate                                   Node                                           SfpRev
DataLinkRateSpecified                          NodeName                                       SfpRxPower
ExternalGbicEnabled                            PacketSize                                     SfpSerialNumber
ExternalGbicEnabledSpecified                   PacketSizeSpecified                            SfpTxPower
FabricEstablished                              PciBusWidth                                    SfpVendorName
FabricEstablishedSpecified                     PciBusWidthSpecified                           SfpVendorOui
FabricName                                     PciClockSpeed                                  SfpWavelength
FirmwareRev                                    PciClockSpeedSpecified                         SfpWavelengthSpecified
HardwareRev                                    PhyFirmwareRev                                 Speed
InfoName                                       PhysicalDataLinkRate                           SramParityEnabled
IsSfpDiagnosticsInternallyCalibrated           PhysicalDataLinkRateSpecified                  SramParityEnabledSpecified
IsSfpDiagnosticsInternallyCalibratedSpecified  PhysicalLinkState                              State
IsSfpOpticalTransceiverValid                   PhysicalProtocol                               StatusAdmin
IsSfpOpticalTransceiverValidSpecified          PortAddress                                    StatusExtended
IsSfpRxPowerInRange                            PortAddressSpecified                           SwitchPort
IsSfpRxPowerInRangeSpecified                   PortName                                       VlanId
IsSfpTxPowerInRange                            PreloadTableRev                                VlanIdSpecified
IsSfpTxPowerInRangeSpecified                   SfpConnector
MaxSpeed                                       SfpDateCode
Another method may be to use the cmdlet Invoke-NcSsh to call sysconfig -a
Invoke-NcSsh "set adv -c off; sysconfig -a"
Hope this helps!
Jonathan Colón | Blog | Linkedin
2 REPLIES 2
jcolonfzenpr
Hi,
Hope this helps!
vishwand
Thanks Jonathan,
i am trying use "get-ncnetport" and "get-ncnode" . we don't have FCports
