ONTAP Hardware
Gracefully Remove Tape Drives and Library from cDOT
hellojon
Is it as simple as doing 'storage tape offline' to gracefully remove an LTO library and its drives from our FAS 8060 running cDOT 8.3?  We're in the process of replacing it with something better and would like to completely unplug it from our FAS 8060.
I've included the output of 'storage tape show' and 'storage tape show-media-changer' below:
filer::storage show> storage tape show
Device ID: 0c.1
Device Type: tape drive
Description: Hewlett-Packard LTO-5
Node Alias Device State Status
filerA st1 offline normal
Device ID: 0c.1L1
Device Type: media changer
Description: HP MSL G3 Series
filerA mc1 available normal
Device ID: 0d.1
filerA st0 ready-write-protected normal
Device ID: 0d.1L1
filerA mc0 available normal
4 entries were displayed.
Device ID: 0c.1
Device ID: 0c.1L1
Device ID: 0d.1
Device ID: 0d.1L1
filer::storage show> storage tape show-media-changer
Media Changer: 0c.1L1
WWNN: 5:001:XXX
WWPN: 5:001:XXX
Serial Number: MXA0XXX
Errors: -
Paths:
Node Initiator Alias Device State
filerA 0c mc1 available
Media Changer: 0d.1L1
WWNN: 5:001:XXX
WWPN: 5:001:XXX
Errors: -
Paths:
filerA 0d mc0 available
2 entries were displayed.::storage show> storage tape show-media-changer
WWNN: 5:001:XXX
WWPN: 5:001:XXX
Errors: -
Paths:
WWNN: 5:001:XXX
WWPN: 5:001:XXX
Errors: -
Paths:
1 ACCEPTED SOLUTION
Sahana
Hi You can use storage tape offline, refer https://library.netapp.com/ecmdocs/ECMP1610202/html/storage/tape/offline.html https://library.netapp.com/ecmdocs/ECMP1610206/html/GUID-97498EB7-D056-4044-BDE0-BB4AEE702B43.html
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
1 REPLY 1
Sahana
